So, last spring I went to remove the port side chain plate cover for re-bedding (it was leaking) and after trying to pry it off to no avail. . .I just set a bead of sealant around all the edges and that stopped the leaking.
Fast forward to today, I pull it for inspection and had to take it off with the cover in place. . .
Why you ask?
It is fully welded to the chain plate
And the worse part is the weld is concave all around. . .reducing the cross section from 1/4" at the CP to less than 3/16" at the weld
I'm not sure what to say. . .Why would someone do this? The weak spot is past all 9 bolts holding it down, kinda defeating there purpose? I guess the two thru-bolts at the cover help hold it down? BTW, the pics below are looking at the underside. . .
I'm not even sure it is worth checking the welds for crack were there is some rust starting. I wouldn't mind making new ones, can I get away with regular covers and CP? Is there any reason to attach them like this?
Thanks!! And thanks to all who responded to my last post. . .The boat is back in the water and hasn't sunk yet
Why you ask?
