Hi All,With the help of the marina I took my mast down yesterday so I can fix the moisture problem in the core underneath the mast step. The wiring for the lights runs inside the mast and the connectors are also inside. My question is can I drill a hole in the mast down near the base to run the connectors outside the mast? A 3/4 inch hole should be plenty. It will make my life easier when repairing the core and also there will be less holes where water can get where I don't have access, plus creating easy access to the wiring. I am concerned that I may weaken the mast.
