While admiring photos of your boats, I noticed a flanged hole in the transoms of some 21s. Found out it was the cockpit drain.
In my 21 the cockpit drain is a through-the-hull fitting directly under the forward end of the cockpit and supports a shut-off valve. How many boats were built this way?
The setup is reasonably easy to service/repair.
The pix was taken looking forward from inside the starboard cockpit locker.
