hole in mast for radar cable
1,750
Oday 31 Redondo Beach
The cable grommet that came with the mast mount for my radar requires a 23mm hole in the mast. About 15/16". That sounds like a big hole to have in the mast. Does a hole that big present any structural / strength problems for the mast?
Thanks
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
I'd look for a smaller grommet.
It may be over sized so the cable doesn't crimp....?
Oct 17, 2011
2,809
Ericson 29 Southport..
That is a helluva hole for a cable. SURELY it doesn't need to be that big.
Unless maybe you're running 440v-3 phase up the stick..
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
Is there a smaller plug on the other end of the cable?
Also most people need to cut the cable at the length where it passes through the deck. This is to allow the mast to be taken down later on without having to cut the cable.
Some use a plug socket here but a better idea is to pass the cut end through a watertight deck gland and to make the connection inside using a simple chocolate strip. Best if this could be in a small plastic box. Such items are available.
Jun 6, 2006
6,990
NO it is not a structural issue. could be a leak one however
Nov 9, 2008
1,338
I'm with the others. Smaller grommet, possibly cut the bottom end off and route it down from the top. Hopefully, the mast is stepped now? Another way to look at it though is to as another question.When routing control lines down and out of the mast, how big is the exit hole and are there allowances to increase sectional properties at the location? I don't know the answer to that, just throwing it out there. If you do have to drill, the best place to do so is in the middle of side which is the longest face, and as close to the bottom as practical. The middle puts it at what I is called the "neutral axis", assuming that the section is dependent on strength requirements not aerodynamics. There is not real stress at this location. Think of the trusses holding up the roof at Home Repot; all those "holes" created by rick-rack steel angles and they still support enormous loads. At the bottom of the mast, the material is mainly in compression so the bending stress approaches zero.
When I routed my wires up my mast, I strung foam marshmallows along the length, spaced about every foot or so. Now, even in quite a blow, there's nothing ringing down my mast, keeping me awake all night. Where they emerged from the mast, I milked the casing from a short length of StaSet over the cover, It helps with UV and abrasion and looks "wick'd pissah".
Well, I'll go back to dreaming of being close hauled while I stare out over a bleak landscape of 18" of snow, ice covered roads and frozen mud driveway. Think of me with pity if you sail.
Don
zeehag
Mar 26, 2009
3,198
boats with wood masts use the exterior of the last as a wire conduit--mine was sillyconed
onto th e outside, forward aspect of mizzen.
aluminum masts need some kind of conduit material for the wires so there is not the noisy clanging one hears from and with internal wires in mast. good luck. it would be ok for the mast to be stepped--makes more sense than trying to find the conduit while mast is standing...
Nov 23, 2011
2,023
I heard of using zip ties. (Those plastic ties you insert one end into the other and zip tight.)
I am going to try this this spring. Attach a large (10-12") zip tie every 12" along the cable that is going to be inside the mast. The tie will push the cable to one side and hold it tight enough so there is no wire slap sound.
(I plan to let a few guys at the yacht club know this trick too. Because I can hear there's slapping at night. I'll provide the ties even.)
