Tim Pinkham
Hi,I had a great weekend hope you all did to.After removing my keel I noticed that the aft endof the keel had worn a hole through the hull nearwhere the drain pipe exits. The damage is a slotabout 3 inches long.Any ideas as to how to best repair the damage?The drain pipe has been damaged also. (as if things weren't bad enough already)Thanks,Tim Pinkham
