My Perkins motor leaks...somewhere. I suspect, with my luck, that the block might be cracked. It leaks all the water out of it. I put some bars-all in it yesterday, but it was too hot to refill and try to see if it works. Can a motor be braised or welded to stop a water leak...if that is the problem?
