Over the past few years, the thru hull vent fitting on my holding tank corrodes to a point I need to replace it. I have noticed in walking around the boat yard that most boats seem to have the same issue. These vents are ususally some chrome plated junk which doesn't seem to last (the same is true for fuel tank vents - Diesel).
I have read here some suggestions so as to avoid clogging to put a regular thru hull mushroom type fitting instead of the ones that are readily available. Does anyone have any suggestions on the materials and ones that last more than a few years before looking all pitted and corroded? Is chrome plated bronze mushroom better, or marelon, or?
I hope to open this discussion to someone who might have found the solution to this.
thanks
thanks
