Hair loss over head installation
I think I am obsessing over a toilet, and I am seeing my shrink tomorrow. I have a few questions I hope you can answer. I am completely rehabbing a 1976 Hunter 30. The prior owner(s) disasembled most of the original equipment and used a band aid approach to repairs. New motor, new wiring, new plumbing, refinished interior. With what we spent for the boat (an absolute steal) , I am not terribly concerned about the cost of updating / repairing what has to be done. Its got a porta-potti right now, and that went in the dumpster this morning. My standards are to 1) do it right 2) pick the easiest approach 3)Maximum Gallonage possible 4) minimize cost.The original plumbing looks like a spagetti fight took place, so its all coming out. I think I have settled on a Sea-Era (at your suggestion) marine toilet. The problem I am having or what I need to know relates to the following.From a practical standpoint the best area to locate a holding tank is in the port V-birth locker, its immediately adjacent to the head, and would require the least hose, fittings and pressure from the toilet (I think).Heres the object of my confusion. In that same (Port V-Birth) locker, I have a Sea Cock (actually a sill cock) and a transduccer in the bottom, both in the way of seating a tank. I am not opposed to moving them as the boat needs new instruments and probably a transducer, and the existing Sill cock looks plain scary. That would open up the locker to something close to a 16 - 20 gallon Ronco (or equivelent) tank, and I can always draw sea water from a different location. I may need to cut the top of the V-bert to get the tank in, but thats not a big deal either. Assuming all that isnt to far fetched, is it okay to have the top of the tank (inlet) about 16" - 18" higher than the bottom of the head (that will put the bottom of the tank and head/pump below the waterline. The head and Tank will be no more than 24" apart. That would likewise put the Tank discharge (pumpout line) about 16" - 18" below the top of the tank (I think), and the discharge hose could be routed up to the deck (pumpout). This does however put the top of the tank and the vent fitting at about the waterline of the boat.There is a manual pump in the head cabinet (not in use) and I am not sure if thats even worth the effort at this point, and would like your thoughts. Do you think we would really use it that much? We live in Massachusetts and I think the only place you can discharge sewerage is on Beacon Hill, in downtown Boston (all the Massachusetts Politicians do it).My wife and I are novice sailors, probably wont be going on any real long trips any time soon, and will probably be looking for a bigger boat in 3 - 5 years.I was looking around the inside of the boat today, and noticed that both the head sink, and galley sink are drained straight to a seacock with no one way valve, is that the way it is supposed to be.If you can answer these questions I will e-mail you a bottle of wine and a dozen head freshners.........
