Holding tank / waste hose leak
H
Hank Park
Holding tank or waste hose leak. I need to know tech info and drawings for hose locations that are not in my owners manual. Also, tips, tricks on handling probably the worst repair job on board. Thank You, Hank Park HBP3rd@aol.com (727) 858-7992
Mark Wieber
Generic Information
I recommend a bottle of 'Pinesol', a box of rubber gloves, and a tool bucket. Also, do NOT forget to close all related through hull valves. Have a plastic garbage bag ready for gloves, paper towels/ rags/ whatever drippy garbage you might have. Find the leak first. This may require a good flash light and some foot powder (spray type works great).Be as sure as possible you have all needed parts before you start. I took the entire offending section out and resealed and assembled it on the dock. In the light. Best of luck! Mark
Dec 2, 1997
8,966
- - LIttle Rock
How do you know anything is leaking?
Have you actually found a spill site? Or do you only suspect a leak because of odor? Regardless, you might want to check out the link below.
