holding tank wall thickness
Rob
Can anyone give me an estimate on how long a 1/4 inch wall will be odor free as opposed to a 3/8 inch?
F
fred miller
Poly Tanks
On my previous boat I had a custom made heavy duty 3/8" poly holding tank. The boat before that had a cheaper 1/4" inch wall tank. Both smelled bad after a couple of years. The thing is the type of poly material used I am told, not only the thickness. In the chemical industy they use Nalgene. My present Hunter has the original aluminum tank . .no oder but I am told is purportedly more susceptable to seam leaking, although you can't prove that by me. My is fine [circa 1992]you just need to regularly neutralize the tank [once a month] with a fresh water flush and regularly pump it out. If I had to replace the tank I would go for stainless steel like on an airplane, and be done with it for good. Fred Miller S/V M Squared
Peggie Hall/Headmistress
Issue is more than just permeation
Walls also have to be thick enough to support the weight of the contents (8.33 lbs/gal)...otherwise the tank bulges, flexes and becomes susceptible to cracking. While 1/4" is thick enough to support up to about 20 gallons (unless the tank is exceptionally tall and skinny) the wall thickness should steadily increase just slightly as the tank size gets larger, to 1/2" or even thicker as tank size passes 60-75 gallons. Note though--there is no hard and fast rule for wall thickness vs capacity...it depends as much on the shape of the tank as the actual size. When it comes to permeation, wall thickness is a factor...but quality of materials and mfrg--especially the curing process--are more of a factor. A good quality 1/4" tank up to 20 gallons will last 15-20 years as long as it's not subjected to repeated stress from a blocked vent and/or fittings aren't over-tightenend. However, a tank from any mfr who starts from a minimum 3/8" wall for even the very smallest sizes will last for decades, and is far more able to withstand pressure or suction from a blocked vent. Bottom line: IMO, you cannot do better than a tank from Ronco Plastics.
G
Gary
Aluminum tanks DO fail!
...and make quite a mess. I'm in the process of replacing the original aluminum tank on my 10-year old boat. There's a hole corroded through the outlet fitting that you can put a finger in. With the hole, the tank couldn't be pumped (no vacuum developed), and it eventually filled (nothing pumps - it must be empty), and spilled when the boat heeled under sail.
