		Jim
My holding tank is building up pressure during use and I figured it wasn't venting properly.  I found that the venting hose seemed to clogged with no ventelation...I followed it and it is attached to the bottom of a stanchion in a spot behind the head medicine cabinet that I can't get to without removing the medicine cabinet.  BUT, I'm looking at the stanchion above decks and there is no sign of a vent hole!?  The holes the lifelines go through are sealed with tubes.  Any ideas?  Could the base be clogged?  Should I drill a hole in the stanchion?Thanks to all,Jim
