Holding tank vent logged
D. Grosz
It seems my vent is clogged as the tank makes expanding & contracting noises when filled or pumped. I've tried to slip the vent hose off at the tank and snake a wire through but the end of the hose is stuck fast to the tank and I don't want to cut it. Any suggestions on how to unclog the vent without destroying the hose? Dan
Dec 2, 1999
15,184
Back flush the vent.
Every time I pump the head I back flush the vent line with fresh water. Just put the fresh water hose in the vent line and let it run. I also put about 3-4 gallons of fresh water in the after I pump it out. This is just the rinse cycle.
Ron Barrow
Check the Through Hull Fitting - From Inside.
Dan: Recently I replaced all hoses and the holding tank on my 1989 33.5. Following our beloved Peggy's advice, I replaced the small vent hose with a 1" variety. When I removed the old vent through hull, I found it clogged with a spongy material. It looked as though the hull liner had been installed after the hole was drilled for the vent fitting, then the fitting was just shoved through the liner and screwed on to the interior elbow. In the process the foam portion of the hull liner was left in the vent fitting. Having owned the boat for 10 years, I had on several occasions backwashed the vent line with water from a hose. Little did I know that most of the water was squirting right back at me. The foam was black with discoloration. Enough air may have passed through to allow the pump out to function, but I have had more than one marina owner tell me that he suspected a problem with my vent line. Rather than removing the hose from the tank, I would suggest removing the hose from the through hull fitting elbow, then unscrewing the elbow fitting from the through hull, and checking the vent fitting from the inside. With the vent hose off from that end, it should be easy to back flush some water through it into your tank (with the shower hose?), as well. Best of luck. Ron Captainronb@earthlink.net
Peggie Hall/HeadMistress
You don't want to snake a wire through it...
That can scratch it, which makes anything from dust to an overflow stick to the inside of the hose. It may not BE the hose that's clogged...it may only be the vent thru-hull fitting....so check that first. In fact, it may not be clogged at all. Aluminum flexes pretty easily. Plus, in MA, you're in fairly cold water..cold water hitting it can make it "jump." If the vent is clogged, you'll feel resistance when you pump the head, and the pumpout will pull a vaccuum--or have a very hard time emptying the tank. However, if it is, I wouldn't worry too much about saving the hose...it can be done, but a few feet of sanitation hose will cost you all of about $10...your time is worth more than that!
Dan Grosz
Tried access to the thru-hull but...
The thru hull for the vent seems to be accessed via a thin balsa panel in the head, which is held on by four wood screws. I took the wood screws off and tried to gently pry the panel out. However, it seemed to be really stuck (factory painted and sealed?) and I don't want to use enough force to destroy it. Any suggestions on how to get at the panel out? Thanks for all the suggestions. -Dan Aquila '92
