I've read through everything and can't find an answer to whether the tank should be upright or horizontal. I've got quick and cheap access to a 35 gal tank from Todd Enterprises. (I need to finish my install!) It is 16 x 15.5 x 36". I've also got the space to install horiztally - 15.5" high, or upright - 36" high. The installed fittings are on the 16 x 15.5 surface so if I place horizontally I will move the fittings to keep them on top.
Upright gives less free water effect, horizontal provides more surface area for aeration. The head is a Sea Elegance so the upright tank shouldn't be a problem to pump into.
Any thoughts? Advise?
