I have this one and it might work, if you calibrate the tank Empty and Full.using a stud finder.
sounds plausible. They work off of density so if you calibrate it while shooting through an empty zone...Read an old post about checking holding tank level (to see how full it is). A few responses suggested using a stud finder. Any comments from readers who have tried this?
Yup, my Stanley Intellisensor does work, after a fashion. I was able to zero above the waste level and it instantly picked up the waste level. Useless to work with as it's a jungle of tubing and thru hull valves and when the sensor is laid on its side, all I could say is that it senses the difference between water and air but you really couldn't do anything useful with it.A few responses suggested using a stud finder.
That also works off of density.... LOL.......Honestly, though, tapping with my knuckle or a knife handle works better, ...
