That depends on several things...
1. Where you sail--offshore where you can flush directly overboard most of the time, or in coastal or inland waters where it all has to go into the tank.2. Do you only daysail, or do you spend weekends or even longer aboard?3. How many people aboard? Depending on your answers, on a boat that small you might be better off with a self-contained system (5-6 gal portapotty that's permanently installed and fitted for pumpout) than with a marine toilet and holding tank. 'Cuz each flush from a marine toilet averages .5 gal...each flush of the portapotty is only about a pint. And the average adult goes 5x/day. So unless you only daysail, a holding tank and plumbing that's big enough to last even 2 people more than a day is gonna use up a LOT of your storage space.As for installation help, check out the link below...it includes detailed instructions for installing a head and holding tank.
