Been there...
Nick,I also own a 1986 272, and installed a new holding tank last Spring. Previous owner had taken out the original plumbing and put in a porta-potty. I was planning a six week cruise and didn't want to deal with hauling out the potty tank every few days. I made a cardboard mock-up of a 15 gallon tank to see how it would fit, and wound up having to only cut about a two inch strip to widen the access port under the forepeak cushions (on the horizontal rather than the vertical plane). I built a platform under the tank to hold it secure in the forepeak, and after some advice from another 272 owner (Bob Todd) I found on this site, the plumbing for my new head went together pretty easily. Finally, I bolted a new brace across the opening that I had cut to enlarge the access port, and was able to replace the piece I had cut out. I did cut a round hole, I think 10" in diameter into the vertical wall of the forepeak liner, and installed a push-in cover to seal it up. This access port gives me reasonably easy access to the lower end hose and the thru-hulls, as well as the depth sounder transducer which I had to replace a week or so into my cruise. It is small enough, with no sharp corners, that I don't think it compromised the integrity of the liner at all. Hope that is helpful. Good luck with yours.Lou
