holding tank removal
Feb 15, 2014
180
Catalina 30 Bremerton, WA
I'm trying to remove the holding tank under the
port settee seat. It's a couple of feet long and
about a foot wide.
It's plastic and I've cut the top off, but I cannot
figure out how it is held in there. Is it glued to
the hull?
Sorry I don't have pix.
Jan 6, 2010
1,520
Jong,
I didn't see the year boat you have but, I can tell you this. My boat is 1980 model & I had to replace my tank also. My closeoff supports were plywood. The upright panel @ the rear of the tank had a hole for the drain fitting. There was a similar panel @ the front w/hole. There was a 1x1 board across the tank top with fiberglass mat adhered to the hull to hold it down. Along the tank bottom running lengthwise was a 1x1 glassed to the hull.
The tank itself can be ordered from BEMCO, they originally made mine for Catalina. There's a part no. on the tank. Very reasonably priced.
I carefully cut & removed the two ends using a dremel tool & removed the 1x1 top hold-down piece. I was able to reuse these & re-glass in. It's a lot easier than having to make a cardboard template & make new pieces. With supports removed you should be able to remove the tank thru the opening. This held true for me however, newer models may not allow this. Usually a lot of equipment like tanks may have been installed before the lower floor liner was installed in the hull.
If not sure, find a glas man. Take pics & measurements before starting & post them here for the guys to give you additional advice.
CR
Feb 15, 2014
180
Thanks for the response.
Sorry, my boat is a 1979 C30. The tank
is plastic and may very well have been
installed before the interior mold was placed.
I'll just keep cutting away at it.
Jul 8, 2011
704
Catalina 30 Sidney B.C.
I installed a new original equipment one from Catalina on my 1982 it went in and out fine through the rear most access panel
