Don
Peggywhen I recently pulled my holding tank to see if was leaking (it wasn't), I noticed that the deck pumpout hose terminated at a side fitting. Thinking the fitting went to an internal hose or pipe which travelled to the bottom of the tank, I tried to remove it for inspection and found there was no hose or pipe. To put it another way, the deck pumpout hose terminates at the top side of the tank. My question is - is this typical and also, if so, how does it manage to remove waste from the entire tank when we pump out?thanksDon
