Relatively new to boat, I have a '91 Hunter 375. It has the original aluminum holding tank and a Jabsco head with the new locking pump handle.
1. For pumpout I've opened the seacock, kept the "switch" to wet flush, and pumped the handle as the vacuum from the pumpout station operated pumping fresh water into tank at same time as I am sucking out waste. Is this correct?
2. My through-hull vent was clogged and I removed it and cleaned it out but still, when I pump out the tank I can hear the tank walls getting sucked in and releasing with a bang when suction stops. This cannot be good. Is there another vent or is the vent hose clogged at the tank? How does one get to where the vent hose connects to the tank? It doesn't seem to be accessible.
