Holding tank pump out
G
Guest
Peggie, I'm thinking of replacing my holding tank/head. (Going with Raritan) My question is on the pump out. I read that someone had a Ronco tank that had a stand pipe for the pumpout outlet. This sounds like a good solution for me but I was wondering if it worked as well as a P-trap type outlet. Thanks for your opinion. -Tom
Peggie Hall/Headmistress
About the same...
When the discharge fitting is on the side or end of a tank, waste will remain in the tank to the level of the bottom of the discharge fitting or the end of the pipe, which about an inch. A p-trap won't change that because the waste can't climb over the "sill" into it. A pick-up tube can reduce the level to about 1/2", but still has to leave that much because the end of the tube has to be cut at an angle. However, even if there's NO difference, I'd go with all the fittings on the top of the tank, with a pickup tube on the discharge any time there's enough clearance above the tank to do it (at least 5"), because that eliminates any standing waste in a hose to permeate it. It also prevents spills if a fitting should fail, and makes re-hosing a LOT easier. A discharge ON the bottom of a tank results in a hose that's always completely full of waste...a p-trap is always full of waste...even a hose that's on the side or end and goes straight up to the deck fitting will stay full of waste to the level in the tank.
E
Ed Schenck
Here's one.
Here is a photo of my Ronco with all connections at the top. Ronco put them exactly where I asked. I needed less than four inches of clearance between the top of the tank and the underside of the v-berth. BUT I had to modify the Ronco supplied outlet, the white elbow. I shortened it before glueing it in. The black elbow is the inlet and I found that at West Marine.
