Hi Peggy,
What a great source of information on marine sanitation maintenance. I must admit I thought I was doing all the right things to maintain the system on my boat, however, now I realize the mistakes that were made after reading your suggestions to other posts. I've placed an order for your book.
I have a 2000 J/120 that I purchased new and the head odor has been getting worse each year for the past 3 years. I've tried K.O., Sealand and Odorless (one brand each year) with no improvement. I've rinsed and pumped the holding tank. I've replaced the hose from the head (Raritan PHII) to the Y valve and the section from the Y valve to the holding tank. I also replaced the vent hose with no effect. The odor was strongest under the cabinet in the head where most of the hose sections are joined and the holding tank pump is located. Last month I removed and threw all the hose away before I read about the wet towel test. I got frustrated and removed the entire system (tank, hoses, T fittings, pump, head) in an effort to get at the source. I rebuilt the head at the same time and took the Guzzler/Bosworth model 500 manual holding tank pump home to clean. I took the pump apart and completely cleaned all the parts and put it back together. It's been three weeks now and the pump still smells aweful. I left it outside so the house wouldn't smell hoping it would get better. I'm now wondering if that was the only source all along. Given what I've read so far, I plan to replace all the hose with Trident 102. The pump seems to be the weak link in the system though. It's plastic but has rubber bellows. This is the factory set-up but does this seem like a quality design? I've been using the pump a couple times a season to empty the holding tank when outside the designated no discharge zone and I now realize I haven't thoroughly cleaned the hose by pumping enough clean water through that section of the system. Before I reinstall everything, I want to make sure I can prevent the odor from returning. Also, I took all fabric items off the boat as they absorbed the odor (sails, cushions, lifejackets, etc) and took them home. Two days after storing this stuff in the basement, I opened the basement door and was hit by the same horrible smell. I plan to wash all the cushion covers and I purchased some PureAyre but haven't tried it yet. I keep my boat in bristol condition but the smell has gotten so bad that my wife won't spend the night on the boat any more until I get the system fixed. Any advice would be appreciated.
Cheers
Cheers
