Ben Stavis
Hi Peggy,We finally launched our boat and are testing the holding tank that I installed last year. You'll recall we had some discussions about the design, and I tried to adhere to your principles. While it works well in most regards, the fumes coming out the tank vent are pretty offensive, often coming back to the cockpit, and my crew (as well as admiral) are advocating giving up on the KO strategy and shifting to bleach, lemon juice, or formaldehyde.The venting system involves two 1" vents, one with a substantial cowl to provide air intake and a 24 hour exhast vent to ensure the air circulates and is removed. I am sure that the tank is getting lots of fresh air. The problem is that the air coming out is offensive. In the long run, maybe I'll have to shift the exhaust vent to under the transom, a run of about 18 feet. Then we'd get the odors only when running before the wind. Maybe I'll have to add a bubbler into the tank.What other suggestions do you have that can make our current cruise a little nicer?Ben Stavisbenstavis@verizon.net
