Don't do that yet...
Did you also replace the tank vent line? If not, it's likely to be at least one of the sources of your remaining odor.The other may simply be "left over" odor from your previous stinky hoses or any spill when you changed 'em that's attached itself to the cushions and every surface in that area. Buy some Raritan K.O. holding tank treatment...it's a live bacteria product that "eats" odor-producing spores (similar products are available at pet supply stores to get rid pet odor accidents, but they’re diluted and considerably more expensive). Clean up any spill area with detergent and water, but don't use bleach, Lysol or any other "antibacterial" product. When the area is dry (no more than barely damp), put some K.O. in a trigger sprayer or pump-up garden spray bottle and liberally saturate the area with it. Don't rinse...let it dry, leaving that area open so that plenty of fresh air can circulate for 24 hours. If cushions were affected, clean up and saturate (not dripping wet…just saturate enough to completely penetrate the foam) with K.O., then leave outside in the sunshine to dry all day. That will get rid of the odor permanently. If you still have odor after you’ve closed everything up again, you missed a spot. And by the way, this also works in musty wet lockers. If none of the above gets rid of the odor, get back to me before you do anything else.
