About bleach
Bleach is not a cleaning product and therefore cannot CLEAN anything...if it could, there'd be no reason to use detergent with it in the laundry. It does, in strong enough concentration kill some organisms, which is why it temporarily reduces odor from a wet dirty bilge, but that's all it can do. So using bleach to "clean" a bilge or anything else is a waste of time, effort and bleach.
Think about it...if you had a wet dirty kitchen sink, would you just pour bleach into it, rinse it out a bit and expect to have a clean sink? If you had a dirty bathtub, would you just pour bleach into it, rinse and expect to have a clean tub? So WHY do so many boat owners think they can have a clean bilge by just pouring bleach into it???
And if you want to find out just how destructive bleach can be to rubber, try adding it to flush water tank on your toilet at home and see what it does to the flapper valve in the bottom of the tank (be sure you have a replacement on hand when you do). That SHOULD be enough to convince you that the stuff has no place in the toilet OR bilge on your boat.
