Gerry...and Darrel
Darrel, you're right that bleach is a no-no...not only is it harmful to the environment, but it also breaks down hose's abilily to resist permeation. Howver, most of the RV holding tank products--especially Thetford's--are far more toxic than bleach. Some contain formaldehyde, but many of those that are labelled "non-formaldehyde formula" only subsitute another equally, or even more, toxic chemical...notably glutaraldehyde or quaternary amonium compound. There are holding tank products, though, that don't contain any toxic chemicals, and are actually more effective at eliminating odor...notably Odorlos and Raritan K.O.Gerry, Yes, plastic IS permeable...but not that permeable. I've yet to see or hear of a permeated holding tank in the nearly 20 years I've been at this...it just doesn't happen. I've run into a lot of people who THINK theirs has, but it's always turned out to be a leak or permeated hose--something that cannot be detected by visual inspection. You can prove to yourself that your tank has not permeated--and whether your hoses have or not... Clean off a section of tank wall down low--and the lowest section of the pumpout hose...that's to remove any odor from another source that may have attached itself to the outside of the tank or hose. Wet two clean rags in HOT water...wring 'em out...slap one against the side of the tank, wrap the other around the hose...leave 'em there till they cool, then remove 'em and smell 'em. If you can't smell anything on the rag that was on the tank, the tank has not permeated....same is true for the one around the hose. If you can, it has. I'd bet real money that the one on the tank won't stink, but the one around the hose will, especially if it's still original.
