Holding Tank Oder
May 31, 2004
24
Hunter 43 Plymouth, Michigan
A couple of years ago I removed the corroded aluminum holding tank and replaced it with a new 3M(?) poly tank. I also replaced all hoses with head mistress recommended hoses. We are not heavy users and had the tank pumped several times each summer. Yesterday, in preparation of winter haul out, we took Endeavor to the local big time marina and had the tank pumped. Business was slow and the pump girl spent a lot of time pumping and rinsing the tank. After what seemed like a long time, she was still getting brown sewage water out of the tank: it would stop, it would bubble, and then it would draw more brown. After the third or fourth rinse, we decided that it was empty. The problem is that when I went below, there was a strong sewage oder. I have never experienced that before except when the tank was full. I wonder if this is normal or gives me something else to worry about this winter. I wondered if one of my hoses came loose but I can't figure how that would happen as each was double clamped. I also wonder if the thorough vacuuming may have cleared the hoses from the heads and allowed the oder to go back through the heads. I tired the "sniff" test in the heads and it did not seem as strong as in the vicinity of the tank. It likely is that this is the first time that the tank got thoroughly flushed and it just stirred up the gunk on the bottom. Any thoughts or suggestions or is this normal with a good flush. Thanks, Art Butler
May 31, 2004
24
No water in the bowls and I did not check the vent line which is certainly a possibility.
Thanks
Art
Jan 12, 2011
930
Hunter 410 full time cruiser
well if you suck all the water out of the head then the holding just vents into the boat
Jun 1, 2009
1,852
Hunter 49 toronto
The water in the bowl acts like the water trap on your toilet or sink at home.
The water in the elbow keeps the stinky gas from venting in.
Once the trap is full of water, the venting stops
Sep 5, 2009
135
Hunter 45 CC Marina del Rey
Tried Noflex! Works great. My front electric head had some obstruction - now gone!
Thanks for your tip!
Viktor
