Dean Strong
Peggy,More questions...I'm replacing a T fitting with a Y valve at my holding tank so I can switch between the deck pump-out and the macerator. With the T fitting, the macerator hose fills up as the tank fills. Just another hose to smell, etc. To insert the Y valve, I had to replace the lower tank fitting, which was an elbow, with a straight fitting. The elbow as VERY difficult to get out, but the straight fitting went in VERY easily (yes, I wrapped the threads with teflon tape). Should I be concerned about this? I'm concerned the fitting will leak. Should the straight fitting have tapered rather than straight threads, for a tighter fit? I thought if you knew off hand it would save me having to tear the whole thing apart again if it leaks...Thanks
