G
Gary
I purchased an '86 Catalina 27 recently. The PO replaced all of the lines to the holding tank. He did not replace the line from the holding tank to the clean-out. the cleanout is located in the anchor compartment. I am not sure how to replace this as there is no access under the forward part of the v berth leading up to anchor well. Does the "fitting" in the anchor screw out. Also cleaning out the tank. Fill it with bleach to remove the smell?? Help
