E
Edward O'Connor- Jaguar
I have read that a number of Hunter owners have experienced holding tank leaks and that these tanks are made out of aluminum. I recently purchased a 9 year old Lengend 43 which in the heat of summer had some head odor. I've pulled the tank which seems to be OK. I will have it pressure checked if I decide to re-install it. I'll also replace the 9 year old hoses while I've got it apart with the best white hosing. Is aluminum o-k as a holding tank. Should I be neutralizing the tank to prevent deterioration of the tank or will going to fresh water flushing protect the tank. If not could anyone recommend a tank builder to replace the tank with a sutiable material.Unfortunately the space for the tank is quite limited so the custom aluminum construction fits very well and holds 35 gallons. It appears that the previous owner had a mascerator problem and that some spillage occurred into the holding tank area. I'll need to neutralize and disinfect the well are now that the tank is out. What would be the best solution to use?
