Kobi..if it is a Wema like we have on our 430..
most likely it is just stuck and needs to be cleaned. If it is a Wema you need to be careful when you remove it from the tank. On the inside of the tank is a ring that matches the ring of screws on the sending unit. You must start by removing ONLY ONE screw and replacing it with a screw about 4" long with the head cut off. This will allow you to then remove the other screws and hold on the 4" screw while you remove the sending unit. You must carefully reach between the sending unit and the tank and hold on to the 4" screw. After you have lifted off the sending unit you then can reach in the tank, hold on to the ring, remove the 4" screw and finally the ring.You can then unscrew the black plastic tube off the sending unit and clean and free up the slide located inside. Hope this helps Dick McKee
