Here's the problem:
Our marina is in a no-discharge zone, which extends for some distance in all directions. Also, there is no place to install the tank within 6 or even 8 feet of the head. The headroom where the existing tank is located is too low to accomodate the unit. Believe me, I wanted to take that option, but could not. OTOH, I plan to replace the forward tank with a lectrosan in the spring, as we have plenty of room for it there. We also explored the option of having a custom molded plastic tank made, but they (Ronco and others wanted to make a mold from our tank at my expense as they did not have one and didn't want to make it from our measurements, and the mold cost was far too expensive (of course after I paid for the mold they would be able to make the tank for others with no mold cost!)Here's an interesting tidbit... The forward tank is failing at all the screwholes on the TOP where the inspection plate and sensor are screwed in, not below where the tank is bathed in urine, so I think it might be electrolysis rather than caused by urine in this particular case. The aft tank failed at the weld of the pumpout fitting to the top of the side of the tank... the fitting just came off, so I don't know why that area failed either. Any ideas? The bottom of the tank we pulled was intact.I wish I were in San Diego too... Great place.George
