To Peggy Hall, Head mistress:
A nearly-fully-plugged vent has kept our sailboat's 13-gallon holding tank from being drained by my wife's daily operation of our maserator pump during our recent 3-week cruise. She complained that the pump didn't sound like it was grinding anything as it used to. We noticed liquid dribbling out the vent as we flushed, but responded only by running the maserator longer next time.
I've since removed the hose to the vent fitting and found the inside leg of the fitting solidly clogged (though I've scraped the fitting from the outside and taped it over before each winter storage).The nearly-clogged fitting only let liquid escape the topped-up tank when manual pump flushing pressurized the tank.
Anyway, with a tank full of weeks of accumulated solids (on the bottom, I suppose), we now can't even pump it out at our marina's pump-out station (we've tried two different pumps!). I've tried back-blowing the 1 1/2" hose to the maserator with our 5 1/2 HP vac to no avail. Flushing the toilet into the full tank produces a solid stream of liquid out the vent, so the vent is now open. Help!! We're dead in the water!!
Is there a powerful chemical that will liquify these solids, or do I have to remove the tank to clean it?
