holding tank fittings
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
I pulled my holding tank (Todd 20 galon) due to a leak at the lower fitting last year. I hate that the fitting is at the bottom and would rather have them at the top with a tube going down internally for the draining. However, with my current set-up, I was wondering the best way to seal the fitting that will be under "water" so that it does not leak. Should I use Marine Tech or something else on it? Thanks Greg
