C
Carl
Back in March Peggy answered a series of questions I had regarding fittings on a new holding tank we are getting. Ronco will make the tank and D&D is making the mold for them. A number of things including Dave, the mold maker, having back surgery have delayed the tank delivery. After again rereading your book and your March 2005 responses in the Head Mistress Forum, I’m still puzzling about the fittings.I understand the vent, its importance and the need for it to be inboard to accommodate heel. Also we can keep the vent hose relatively flat, probably 35º off the horizontal, and certainly under 45º.We will have Ronco add an internal suction tube for the discharge. I read your recommendation to put the discharge fitting on the top of the tank. I can do that with a lot of effort in routing the 1½” hose. The existing discharge hose would install much more easily if I had a fitting on a vertical tank wall. It would result in 5 or 6 gallons of the 20 gallon tank being above the discharge fitting. The hose from the discharge runs to an existing Y-valve. I’ll keep that valve rather than install a second, off-shore discharge fitting. I found 90º elbows from Marine Products International under sealandservices.com and am considering using them to route the hose from the head to the tank. Elbows would let me more easily route the discharge hose from the top of the tank to the existing Y-valve. Would I be better off with elbows or a wall mounted fitting? What problems will I have if I install the discharge on the vertical wall rather than the top of the tank?I have only 5-3/4" forward of the tank to route the 1½” inlet hose. I’d be able to keep the hose shorter and the vertical rise lower if I used two elbows, including a 90º elbow at the inlet fitting on top of the tank. I think that is better than a loop of hose above a vertical nipple on the top of the tank. Is it?The one part of your earlier recommendation I do not understand is the need for the inlet fitting to be inboard. The discharge of the head is close to the athwartships centerline of the tank and about 20” below the top of the tank. The head and tank are on the port side of the boat. When the boat heels on a starboard tack, the contents of the tank will run to its outboard side and back up to the inlet if it is outboard. By the same token, on a port tack the contents will back up to the inlet if it is inboard. The head outlet, being pretty much on the tank centerline would be the same height below either the inboard or outboard fitting when the fitting is “downhill.” I know the outboard fitting will get closer to the waterline, but the waterline is outside of the boat and as long as I have the head inlet valve closed the sea water better stay outside.My bottom line from the preceding paragraph is I can’t figure out the preference for an inboard inlet fitting. I’d locate the fitting on top of the tank near its centerline to minimize the length of run from the head.And in anticipation of Peggy's question … we installed a Lectra/SAN in our other head a few fears ago and love it. The tank replacement is to get us into no discharge zones.
