holding tank cleanout
Mar 16, 2012
1
morgan out islander 33 marathon
My tank (rectangular) measures about 2 cf which is should be about 15 gal. Lately on my weekly pump outs they only are getting 8-10 gal after I had topped up the tank with water. Cleaned the vent which was clear this time. Is it reasonable that nearly half the tank is sludge not being picked up by the pump? I cannot think of an alternative explanation.
Assuming it is sludge, what is my best procedure? hot fresh water w/ laundry soap; add , pump repeat until water reasonably clear? if so how much water, how much soap?
Dec 2, 1997
8,946
- - LIttle Rock
If it's still sludge that hasn't turned into "concrete," you can flush it out of the tank by putting 3-4 gallons of water into it via the deck pumpout fitting--'cuz that sends the water into the tank at the bottom to stir up the sludge and hold it in suspension so it can be pumped out...pump that out. Repeat...repeat...repeat...till you're only seeing clean water in the pumpout hose sight glass.
If you're not seeing "mud" in the sight glass even the first time, it means one of two things: 1.whatever is in the tank has turned to "concrete"...or 2. There isn't any sludge in the tank...highly unlikely, but it shouldn't be more than an inch or two, certainly not enough to account for 5+ gallons. Most likely it means that any pickup tube inside the tank was cut too short or any discharge fitting on the side or end of the tank was installed too high. So when the level in the tank drops below the end of the pickup tube, or below the top of the discharge hose fitting at the bottom of the tank, suction is broken...preventing the pumpout from pulling out any more. The pickup tube should touch the bottom of the tank and cut at about a 25 degree angle...a discharge fitting at the bottom should only leave about an inch in the tank.
As I typed I thought of one more possibility: if the discharge is at the bottom and the tank isn't level, but tipped to put the discharge fitting at the high end, the pumpout wouldn't be able to get any more once the level drops to the top of the fitting.
If you do have several inches of "concrete" in the tank, I ran across a product at the Strictly Sail show in California this past weekend called "Tank Tech" which the mfr claims will dissolve it. You can read all about it on their website TankTechsRx.com They're just starting to break into the marine market with it, have been the RV market. I'm not endorsing it and will be checking it out with my own expert sources. Meanwhile, it's not expensive, so I don't think you have much to lose by give it a try.
Mar 20, 2012
3,983
there are three thoughts here....
remove the tank and clean it out, and then reinstall with new hoses and parts as necessary so that its works dependably for another lifetime..
or you can pump in some clean water and use an enzyme to eat away at the "assumed" waste in the tank, and this may take some time (a month or two) and then it out pump out, by adding positive ventilation, or better yet, an oxygen "drip" to feed the bacteria, it will speed things up....
the third thought is, pour in a bleach solution and let it dissolve the "assumed" lump it in a few days time.....
bleach is never a good idea in a septic system because it kills the all the bacteria necessary for a septic system to work, but in a holding tank where it will be pumped out it can be beneficial, as it WILL dissolve the lump....as long as its NOT pumped in to a septic system, which is different than a municipal sewage system. municipal sewage systems can handle chlorine, but they dont like formaldehyde based products.
it would be a good idea to know if there is a build up in the tank before trying any of the methods, because its rare that a small marine holding tank has this kind of problem because of the constant rocking/agitation it receives....
forbin
Nov 4, 2013
166
Tartan 3700 Seattle - Elliot Bay
I've been using Noflex which sounds similar to the TankTechs product. I started having trouble pumping out and it was recommended as something to try before taking stuff apart for 'manual' intervention, which I *really* didn't want to do. I've only pumped out a couple times since beginning use of the product but each time the first few seconds of flow have been pure nastiness which I have not seen in the past three years of having this boat...so I think it's working. I've also noticed that there is no head odor anymore, there used to not be much but now there is none, so that's great too.
Jan 4, 2006
7,268
One way to ensure the tank contents are well shaken (and not stirred) is to take the boat out on a rough day once the chemicals, fresh water, or whatever, is in there.
Likes: woodster
