Last summer I noticed oil in my bilge water (we always had bilgewater because the packing gland was leaking all summer). So I found the source of the oil leak back by the transmission where it was extremely hard to clean up and get access to.
It just so happens that I wanted to replace my engine mounts and install a PSS shaft seal so now I have the engine removed and can fix all kinds of things. The photo of the transmission shows the leak just over the stained rags. It appears that oil is dripping from the shifting linkage. The engine is a Yanmar 1GM circa 1984 (rebuilt by PO sometime around 2001).
When I found the oil level going down last summer, I added transmission oil instead of the regular diesel grade oil that is recommended by Yanmar. Is that a major no-no?
Another question, what is the purpose of the red tank that is in-line with the exhaust?
The shaft currently shows the rubber hose still attached to the stern tube (in case anybody was wondering). I can't wait to see how the new shaft seal performs - I'm tired of trying to adjust the packing nuts and getting in there to remove the packing would have been a nightmare. I hope to have a permanently dry bilge for a change!
Another thought I had was to replace the original 35A alternator with a new one that will charge just a little bit faster.
