Hitch Extenders
Aug 8, 2013
59
Catalina 22 Scituate
Anyone use a hitch extender? Depending on the tide I have to put a bit if my chevy colorado in the saltwater which I'm not a fan of. I have a dual axle trailer that sits level on its own so there is no tongue weight to worry about. I have a class 3 hitch that is rated for 4000 lbs gvw. From what I read an extender cuts the tow rating in half so I would be over the rating for towing my boat by 1000 lbs or so. Anyone else have this situation? It would be a pita but I guess I could add the extender just prior to launch and haul out.
Aug 8, 2013
59
I have a buddy who can weld maybe I'll see about making the trailer itself a little longer. For now I think I'll get one and just do that much more fiddling at the launch.
Sep 30, 2009
98
Catalina Capri 22 (loved my old C-22) NorCal
Have your buddy fabricate a tongue extension to your trailer rather than an extension to your receiver hitch. You want the tongue weight as close to your bumper as possible to reduce the moment (weight x length) at the hitch. It could put too much stress on your receiver causing it to fail. It becomes a lever, just like a breaker bar for loosening stubborn bolts.
You can fabricate a stronger tongue extension to the trailer which will actually reduce the tongue weight on the hitch when extended. Many C-22 trailers have extendable tongues which is simply a smaller square steel tube that slides inside the larger tube of the trailer frame held in place with two pins.
Check out this thread:
http://forums.catalina.sailboatowners.com/showthread.php?t=141050
and this page:
http://home.comcast.net/~catalina22fleet20/techtips/trailer.htm
Caish
Jul 23, 2011
12
Catalina 22 Home
Here is an Idea I had for those long shallow ramps.
Make/tire to the top of the trailer beside the keel.
Now your not overloading the hitch and you an keep your truck/car out of the water.
Another option was just to line it up and hook it to a chain and clevis that will not come loose. Let it roll into the water with chain taught ad will roll straight back.
2,315
Catalina 250 Bodega Bay CA
I don't see any reason why a 3' extention can't be used in the truck reciever as well as the trailer tongue extention. I used the trailer extention to get my 250 wing into the water at Bodega Bay but had to put my rear wheels into the salt water to get it off and didn't like that! In November I will have to get her back on and intend to use a 3' truck reciever extention and the trailer extention. This will only be used at the launch and the tongue wheel will be down to just touch as I back down. My spare tire is designed so it can be rotated and lowered for tongue support if needed. Chief
2,315
Using as low a tow ball as practical is also an inportant concept as lowering the front of the boat/trailer can help launching a lot. Adding more length to your trailer entension would work great. Just be sure the extension addition is STRONG! Chief
Nov 26, 2012
2,315
Follow up for all trailer sailors. I retrieved my wing keel Cat 250 just before Thanksgiving from Bodega Bay launch site after it had been in the marina for 2 months. I had a 5' extension made for my truck reciever,used that and used the tongue extension on my trailer and pulled her out with no problems! Tires just in the water. Chief
Aug 8, 2013
59
I ended up going with a 12" and it worked just fine. Just a hassle putting it on and taking it off at the launch. I'll be mooring next season so won't have to deal with it too much...
Nov 26, 2012
2,315
upslims: I messed you and others up with my post. I just corrected it to be 5' not 5"! Sorry about that. Chief
Mar 26, 2012
227
Catalina 22 Pflugerville
I hope that I'm not hijacking this thread, but I have a question relating to hitch extenders. I have an F350 long bed quad cab truck with a single rear wheel axle and have been considering getting a truck camper for it. There are many options out there and the one that we like best has an 11 foot floor. Trailering the C22 with this camper would require about a 3' extension, which the manufacturer shows in use with their literature. The truck weighs about 7000 lbs and the camper about 2500. The camper's CG is 51" back from the front edge of the forward end of the truck bed, placing it well forward of the rear axle. Im not concerned with the towing capability, as we'd only be at about half the capacity. I'm just wondering if there are any others who have experience with this or a similar configuration and how it worked for you?
Nov 26, 2012
2,315
upslim: I missed your query about towing with the extension before. No, I would not tow with any extender in my reciever. My 5' unit isn't much of a problem to use at the launch and if it isn't then anything shorter should be easy! Chief
Tom J
Sep 30, 2008
2,319
Catalina 310 Quincy, MA
My son has an F350 quad cab dually with an Amerigo camper. He tows a heavy dual axle trailer with a 5' extension from the truck hitch to the trailer hitch, under the camper. He installed air bags on the truck, turnbuckles on each side of the extension, and a leveling harness on the trailer hitch. The rig rides level and is very stable on the highway. I couldn't believe it when he showed me the speed recorded on his GPS during his latest trip!
Sep 12, 2013
76
Catalina 22 Dillon, CO
Way over kill. Any small SUV or small truck, Tacoma or Mazda B2000 can easily tow and launch a C 22. These are just trailers with Fiberglas bath tubs on them.
hewebb
Oct 8, 2011
329
Catalina Catalina 25 Joe Pool Lake
To launch my 25' WK, I use a 16' extension made from a 2" piece of channel iron. Ball on one end and hitch coupler on the other. (Some folks use a rope or chain) Trailer has third wheel that I attach to the front of the trailer that takes the load and keeps the trailer straight going down the ramp. Some what of a pain to use, but works well.Most of the 22' boat trailers have an extension that is built in.
Nov 28, 2012
148
Catalina 22 #442 Somerset, Ma
if you don't mind a picture would be great. i have a good idea of what your talking about but im a visual person....lol
Mar 26, 2012
227
Thanks Tom, that's what I was looking for, someone with some experience with towing with a truck camper. Somewhere I saw a pic of a C22 owner who was showed his rig behind his truck camper but not sure if he required an extension. I realize its more truck than needed to pull a C22, but it's what I have and the idea of having a bit more creature comforts available on trips and the ability to bring the boat too just really appeals to my wife and me.
Again, with apologies for what I now realize should be on a separate thread.
