More thoughts
Pierre,My stock 26x trailer has a 2" hitch. Apparently Macgregor thinks this is appropriate. These run light on the hitch weight, depending on the position of the boaat. Mine is about 100 lbs. Mac's are famous for moving back on the trailer as they are pulled out of the water. This moves the center of gravity even farther back, and makes the hitch weight even lighter. Most vehicles with a 2" hitch ball will handle it OK. Always attach twin safety chains, just in case. Another thing, the stock trailers have surge brakes. Mine are very effective. When the car stops, the trailer stops too. Hills can be a problem if you have a smaller engine. Watch the engine temperature and downshift early for big hills. Don't let the engine lug in a high gear. Good luck!
