During the last four years I've been experiencing an irregular electrical short in the boats DC power source. This happens when I attempt to turn on power to the power panel located in the cockpit to start the Volvo 2002 series engine. I've had the main cable from the panel to the starter checked out. Replaced the starter and fuse panel block located top of the engine Sometime, if the switch is left on, the power will come on. Other times, I move the wire at the fuse block to another connection and then the power will come on. About twelve months ago, the last time I had the problem, I sprayed the electrical connections with a conductivity spray and it has been OK until recently and again it is a hit and miss situation. If anyone has information on how to best solve the problem, please speak you piece.
Thanks, Larry on Moonstone 99.
