Hight Spec. Keel bottom to Cabin Top, H30/89
160
Hunter 30_88-94 Edmonds, WA
Boat Information
Look on this site under "Boat information." All the specs are there, and are accurate.
Jul 14, 2004
6
- - N/A
Spec. Measurement
Not sure which of the spec.values listed for the Hunter 30 '89 model is the keel bottom to cabin top height. Assume it is the 9'9"?
Dec 10, 2003
160
Cabin height
Those specs won't give you what you need. 9'9" is the "J" value, or the distance from the mast to the bow. "I" is the jib luff (forestay) "P" is the main luff (height) "E" is the main foot. (along the boom) Nevertheless, having just extensively measured my 1990 Hunter 30 (identical to '89/30) for a new main sail, I might be able to help you. From the waterline to the top of the mast is 50' Draft (waterline to bottom of keel) is 4'3" So bottom of keel to top of mast is 54'3" Maximum Halyard hoist to deck is 44'1". Add 8" to reach the top of the masthead (the halyard doesn't hoist the mainsail to the very top of the mast), so top of mast to top of cabintop is 44'9" Therefore bottom of keel to cabin deck at the maststep should be 54'3" less 44'9" or approximately 9'6" Hope this helps you get your quote.
