Shackles for H.T. "G4"
You’ve put your finger on the problem we have in matching the various ground tackle specifications & sizes. Generally, to achieve a WLL of 4,000# - it takes a ½" S/S Shackle, with a 5/8" Pin, normally useable with 1/2" Chain. Given your 5/16 G4 high tensile chain which has a working load limit of about 3900#:Take a look at Euro Marine Trading: http://www.euromarinetrading.com/Anja: http://www.euromarinetrading.com/PDF%20Files/Shackle%20Catalog.pdfSee pages 6 &7 - “Forged AISI 316 or AISI 17-4 S/S” Shackles.It appears you could use their:316 S/S Captive Bow Shackle #753-3/8" ~ 4,630# WLL & 5/16" Pin17-4PH S/S Screw-Eye Pin D Shackle #732-1/4" ~ 5,500# WLL & 1/4" Pin17-4PH S/S Screw-Eye Bow Shackle #752-1/4" ~ 5,900# WLL & 1/4" PinAlso see their notes on “limits” on page 2.To determine Straight* Working Load Limit (WLL):Divide Proof Load by 2.2 Divide Breaking Strength by 6* A “Side” Loading requires a further (large) derating, depending upon exact geometry.See also “Anja”: http://www.anja.noHTH,Gord May
