Bob
I'm looking for some other sailors who have High-Output Alternators on small Diesels (Yanmar SB8, for example). What I am searching for is the real world experience of whether you use a high-output alternator on a small HP (8 HP) diesel, and if that experience is a happy one?I've heard stories about water pumps shafts being sheared and warnings about excessive loading causing crankshaft problems, and reduced prop shaft power due to excessive loading caused by a high-output alternator (125 AH vs "stock" 35 AH).There are other stories abot people using a by=pass switch to reduce the field to the alternator, so the loading can be minimized when shaft output power is more important or delayed while starting.Please bear in mind when I say "stories", I mean sailors describing their experiences.I have looked at the Yanmar GM series as well as the SB series, and I fail to see what adverse connection there is between the alternator and the water pump, except for a parallel flange on the pulley on the crank shaft pulley?I need to redo my entire DC charging capability, and although have several excellent resources, I still sense some disparity between using a High output alternator with its corresponding load. According the Balmar web site, it takes approximately 1 HP to produce 25 AH of alternator current. At the theoretical "fill load" of a 125 AH alternator, that's about 5 hp out a practical 7 hp Yanmar SB8 diesel.Thoughts, opinions, facts, experience?
