High output alternator
Ted
I have a 1987 Catalina 36 with a M25 Universal. I am thinking about upgrading the alternator but have some concerns that doing so may cause the engine to overheat. Anyone have any experience with upgraded alternators? Any recommendations?
Jun 3, 2004
28
Catalina 36 Bristol, RI
I haven't had any problems
Ted, I upgraded my electrical system on my 86 C-36 with no issues. I have an Ample Power 125 amp alternator and have never experienced overheating due to the alternator. One thing you should do is use a high-quality fan belt such as a Gates "Green Stripe". You can get these at NAPA auto parts. There is one person who upgraded his alternator with a 90-amp alternator that uses the same body as the stock Motorola. Check out the International Catalina 36 Association web site for the details. Good luck, Les Murray s/v Ceilidh '86 C-36 #560
Jon W.
May 18, 2004
401
Catalina 310 C310 Seattle Wa
Alternator and M25xp B
I went with a Balmar 75 amp model. That's about the largest they recommend with the 3/8 inch belt. I had to get a slightly longer belt, but used the stock mounting with just a little filing to make it fit. I've had no problems, just a little more belt wear, although I'm still on the first one I put on four years ago. No increase in engine temperature. The biggest improvement went to the 3-stage external regulator I put in at the same time. I think the stock alternator can be converted to use an external alternator configuration.
C36 Association
Ted You have a C36. You should go to the C36 Assoc. website. There is a very good writeup there of just what you need. Stu
