Anyone know if the wiring harness has any fuses in an inconspicuous location? I'm stuck with no juice to the instrument panel. When started engine to motor into harbor last night everything started just fine. Then got a "high voltage" warning on my depth instrument display and the volt meter was all the way over to 16 volts. Didn't have any issues getting in to harbor. All gauges looked to be working fine. After I shut down engine and turned off key, I turned key and had no power to instrument panel/no engine starting. Thanks for the help!
