Dave
In process of restoration of H-23. I contimplating using an all electric (130lbs thrust) dual trolling-motor configuration to replace gas outboard engine. Plan to utilize solar panel to recharge and a bank of three 12 volt deep-draw sealed gel-type marine batteries with a voltage isolation circuit for the 12 volt lighting and instrument power. I understand this motor configuration is used to power pontoon boats in pristine-water-regulated areas. My thoughts are the entire investment will cost less than $1200 (8 hp Honda 4-cycle @ $1800?), and will require no gasoline purchases, nor will it polute the environment. Question for the engineers out there: What amount of thrust is required to push an H-23 against 20 knot winds in two foot chop at a rate of three knots? perhaps I should call Hunter on this one?Regards,Dave
