on the all sailers forum, but I guess my issue was unique to the 37C with a Yanmar 4JHE. I couldn't get to the raw water pump impeller on this engine without taking the alternator off and then the impeller housing face plate is facing to the back of the engine and I am in the front so I have to work at it blind. I had no access from the port side of the engine. The alternator is right up to quarter berth wall as well as the pump behind it. The the quarter berth access door opens to the transmission and to is to far aft to get to the back of the pump and the impeller. Jeeze, it was a bear to change out and I didn't need to, because once removed I found the impeller in great shape. Turns out it was mixing elbow blocked. Don't most engines have the impeller cover right at the front of the engine so easy to inspect?
