I'm looking for creative ideas about locations for an HF radio to install either semi-perminantly on the boat, or to take it on and off for my times away.
Questions:
1) radios need direct battery connections, as they can intermittently chomp 20A of power in transmit mode. Also, they suggest keeping wire runs to minimum length. Thoughts about running wire direct to the battery? Or do you connect through the main power switch into the House Battery?
2) this is not a marine-grade, salt resistent radio, so I'm looking for a clever location to avoid getting wet, while still being handy.
3) has anyone had success installing a rail-mounted multi-band (80, 40, 20, 17,15, 10M) antenna, using just the rail and lifelines as a counterpoise? Any thoughts about installation of antenna tuners?
Also, I'd be pleased to connect with other Vega Hams, on or off-line.
Kevin Vega 1039 VE7KHI
PS, Spring shakedown sailing in the Georgia Strait, BC has been delightful. Trip to Pricess Louisa Inlet set for next week.
Questions:
