Bruce bias
While I think any plow-type anchor (Bruce, Delta, CQR) will work really well in our nice, sticky, mud, I prefer the Bruce.With the conditions we have in MW, my observation is that 90+% of anchoring problems are caused by bad sets and current swings; not a lack of holding power.I like the Bruce because it sets first time, _every_ time, and re-sets as easily when the boat swings 180 degrees (which it does often here). If you keep your Danforth and carery it as a second, you'll be well protected in the improbable event that you're caught in a blow the Bruce won't handle. Regarding chain, I'd go for the 100'. In fact, I'd carry as much as you can without pushing your bow down into the water. Chain allows you to use shorter scope, really important when you're anchoring in 40-50' of water.
