A couple of more comments, Mark
to your last post2. don't drain the engine, drain the muffler as Bill says.3. "I tried opening the plastic bleed knob on top of the Racor and the knurled knob on the fuel bypass at the engine, both singularly, in sequence, and at the same time." DON"T do that. All that does is let more AIR INTO the lines, which is exactly what you are trying to get rid of! Think of it this way: you WANT as closed a system from the fuel tank to the nut on the engine filter housing as possible. You are trying to get rid of air inside the lines, so it needs to be closed from the tank, to the pump to the Racor to the nut.At the risk of repeating myself, if it's an M25 (which you should be able to see on the decal right aft of the thermostat housing, the M25s knurled knob doesn't do a thing (at least on my engine). The M25XP seems to use the knurled knob method. Similar but different engines, but I still believe the secondary housing nut is important. Why - because it is the first place for the air to get blown out of the system. The knurled knob is downstream of that on the way to the injectors. I find if I get the air out at the housing, the knurled knob doesn't do anything more, and it works. The nut on the secondary filter housing is the only place it bleeds properly for me. And, I do not bother filling the new Racor, that's what the fuel pump is for. It's not so hard, but I gotta admit I took me too long to learn how easy it really is. I put it off for six months because I was (I admit it!) afraid to do it. Once done, it's child's play."4. I'll check the fuel tank pickup screen for clogs, drain the water from the engine,..." Drain WHAT water from the engine? I assume you mean the muffler. The rest of this paragraph is OK.Good luck, keep us posted.Stu
