HELP
Paul
The factory site states that they use a hand layup of fiberglass and POLYESTER resin. Why doesn't McGregor use Vinylester or do they? It is suppose to be more blister resistant. Does anyone know what the Min / Max thickness is of the hull? Also, what is the number of plys of glass cloth/roven that is used in the hull of the newer (1995-2001) models? Also, what type of stove/oven/heater is recommended. It gets a little cool up here in the NW. Thanks for all you help
Dean Smith
Hull thickness varies a lot
I can answer some of your questions. First, I don't know what specific kind of resin Macgregor uses. I'd expect it has changed over the years, having once been in the fiberglass industry. Second, hull thinkness varies a lot. In my '96 26X, it goes from about 3/4 inches or more in the high impact areas -- bow, etc -- to about 1/4 inches in the low impact areas. This is to keep the trailer weight down. We accidently put a hole in our hull (don't ask me, it's too embarassing) right in the head area and the glass was only 1/4 in thick there. Fortunately, it was easy to fix and the repair shop did a great job. (Ollies in Lynnwood, WA). Stoves and Heaters: We had Blue Water Yachts install a single burner alcohol stove. I have seen other installations that are also designed to be cabin heaters. The first couple of years, we heated the cabin with that stove and a couple of candles. But last year we added real heat -- an electric heater which required that I first install shore power -- and a alcohol heater from West Marine. The later is great. It puts out about 5000 BTU which is plenty and it doubles as a second cooking burner when needed. We have been quite happy with it.
Steve
Vinyl Ester Resin
Paul, Vinyl Ester resin is more expensive. Simple as that. The Mac, and most other boats still use polyester resin for their laminating. I have seen a couple of manufacturers advertise that they are using vinyl ester for the outermost layer of laminate. This is a good idea and I wish they all would. It's really quite easy to get the vinyl ester protection on a polyester boat. Duratec makes a vinyl ester high build primer, that is compatable with most paints, gelcoats and resins. The hull thickness is about right, in the other response. They high stess areas are up to 15 layers of laminate. MacX #1374
